CDI Part numbers
Verfasst: Mo 31. Aug 2009, 15:33
von reborntoride
Need a bit of help confirming that the correct CDI for a 97 TT600 4GV motor is 3TB-82305-00 ..
  Thus, with a CDI 3YD - 82305-00 also work or not?
RE: CDI Part numbers
Verfasst: Mo 31. Aug 2009, 19:07
von holgeraushh
Hi reborntoride,
i dont know the part numbers of the ignition-moddels, but if you know the exakt bike moddel where the ignition from, then look here:
http://www.xt600.de/xt_werkstatt/_techn ... /index.htm
and compare the ignition secifications.
But attention, the main differnce between some kick and electric moddels is the functional principle of the ignition.
The e-models has often an T.C.I.-ignition
The kick-models an C.D.I.-ignition
These ignitions are absoloutly not compatible.
Only TCI to TCI and CDI to CDI are compatible if the other specs the same (or nearly). Only then you have a good chance it will work.
And by the way, we have here in the forum a special guy, he repairs some ignition moddels. He calls "Gerd_J". You can contact him per PN or E-Mail via ouer forum. Maybe he can repair your original ignition.
Best Regards Holger
RE: CDI Part numbers and TCI
Verfasst: Mo 31. Aug 2009, 23:09
von Gerd_J
Hi ;-), Oh what a pity :-(, nothing more to say :+. Cheerio
Verfasst: Di 1. Sep 2009, 10:27
von Steffen
I could add the cable configuration and the type (plate) of the 2KF ignition box.
Karlsruhe, Baden
Anhang #1 (2899.jpg)
Anhang #2 (2900.jpg)
