Auspuff XT600 1995 auf 2KF?
Verfasst: Sa 9. Jan 2010, 16:14
von johanv
Does anybody know if a exhaust of 1995 XT600 will fir on a 2KF without any problems?
RE: Auspuff XT600 1995 auf 2KF?
Verfasst: Sa 9. Jan 2010, 23:08
von Steffen
Hi Johan
Normally it does, but there are several exhausts made for the 3tb from 1990-95 which have an additional frame/bar. If you can remove this frame, it will fit on the 2KF, but you have to find a way to mount it to the rear screwhole of the 2KF-frame.
A picture or a model name of your desired exhaust would help.
Karlsruhe, Baden
Verfasst: Sa 9. Jan 2010, 23:47
von johanv
Vielen dank! I'm talking about the laser produro pipe.
Verfasst: So 10. Jan 2010, 11:32
von Steffen
There are two different versions of the laser pro Duro. One for the old modells and another one for the 3TB and Co.
I'm not sure about the difference, maybe its only the additional material for mounting.
You can ask KED0, the sell both. Go to [link:www.kedo.de?f_support=www.xt600.de|KEDO] and look for the article numbers 90070 (2KF) and 90071 (3TB). You can also change the language of the site onto english, its dotcom instead of dotde.
Finally, you can call KED0, I'm sure they're willing to help you. Maybe they can tell the difference.
kind regards from snowy-white germany
P.S.: the phone number should be from abroad +49 4040170200
Fax is +49 4040170201
and from germany its (phone/fax) is 07002255-5336 / 6789
they also have a mail adress (info@Ked0.com) KED0 is written K E D O, not K E D "Zero" (dont copy and paste the mail adress, wount work)
adress is steilshooperstr. 33, 22305 Hamburg, germany
Monday - Friday 10-18 o'clock
and they will ship abroad
Karlsruhe, Baden
Verfasst: So 10. Jan 2010, 12:15
von johanv
VIelen dank!
