>I have recently acquired a good condition 1986 XT600 49N
>motor with under 9000 original kilometers...
>from google translate
>Ich habe vor kurzem einen guten Zustand 1986 XT600 49N Motor
>mit unter 9000 Original km erworben...
In my first post is a calculation error of km to mi that I made. 9000 km is incorrect. I should like to correctly state the engine I am working on has 22,500 km. The chassis I am installing into has close to 42,000 km.
Ausgangswelle Ersatz und Fall Schweiß
RE: Ausgangswelle Ersatz und Fall Schweiß
Liar ! This enginge was never running. It is much to clean inside
Definitely!
I´ve never seen a 43F-engine´s insides in such good condition before...really keen on pictures of the transmission-gearwheels...
You wrote:
"....Also when the sprocket wobbled the chain notched a minor grove into the case. I should like to get this groove welded up. I am wondering what the cases of these 80s XT600 is. Aluminum? or Magnesium?...."
Instead of welding consider something like this:
http://www.autobarn.net/j-b-weld-stik.html
Beautiful condition!
Wondering weather the 5. gear is beautiful as well?
